Will LS7 clutch work with SPEC flywheel?
The LS7 clutch requires a flywheel that is recessed. That being said we actually offer several flywheels. The normal LS1 type flywheel (which you probably have now) is flat and it has a part number of SC75S or SC75A. Our LS7 unit that is intended to work with a stock-type LS7 clutch is part number SC66A-2. Check the part number and let me know if you have any further questions. Thanks!!
