McLeod Street Twin on Stock Hydraulics?
Old 10-07-2011, 07:19 PM
roadtrip120's Avatar
Default McLeod Street Twin on Stock Hydraulics?
Will a McLeod Street twin work on factory hydraulics or do I have to run the McLeod Slave cylinder?
I called McLeod but they are closed, looking for a quick reply.
Old 10-07-2011, 10:53 PM
got-a-ls1's Avatar
ill be running stock with mine.
Old 10-08-2011, 12:24 PM
AChotrod's Avatar
They said I had to run the adj master when I put mine in. BTW I have a Street Twin/flywheel and adj slave for sale if you havent bought the clutch yet. Less than 1k on it.
Old 10-11-2011, 12:26 PM
Billy M's Avatar
We highly recommend using our large bore master cylinder with our LT-1 & LS-1 Street Twin so much so that if you use the OEM master and burn up the clutch it will void any warranty with McLeod.
Old 10-12-2011, 12:25 AM
got-a-ls1's Avatar
hold on... the street twin is different from the rst/rxt correct? im running rxt and i remember you saying to use stock master... is that correct? i forget that mcleod has a different twins
Quick Reply: McLeod Street Twin on Stock Hydraulics?
