T56...issues
Old 10-08-2011, 06:28 AM
boosteddragon's Avatar
Default T56...issues
A friend of mine t-56 is grinding in 3rd gear and hard to either get in or out of 4th,but every other gear is smooth.
what would be wrong with his trans?
Old 10-09-2011, 08:09 AM
come on....T56 peeps fellow tech'en needs advice!!!!!
56 views and no reply.
Old 10-09-2011, 10:16 AM
thesource's Avatar
Probably has bent or broken shift keys in the 3-4 syncro assembly. Its a common problem with T56 transmissions and can be resolved with a solid key instead of a stamped key in most cases.
Old 10-11-2011, 03:40 AM
greatly appreciated!
Old 10-11-2011, 06:20 AM
toadzq8's Avatar
Yep! agree, 3-4 keys + fork pads now.
Old 10-12-2011, 05:31 PM
TDP
TDP's Avatar
It's time for a rebuild. If 3-4 is acting up, then the rest of the trans isn't far behind. In order to do the job right, the trans needs to be completely freshened up and upgraded (like mentioned above). There's not necessarily just a part or two that need to be replaced. If you decide to send it off for a build, check my sig. We have a very quick turnaround.
