Throwout bearing???
Old 10-12-2011, 09:32 AM
spike30th's Avatar
Default Throwout bearing???
I need some opinions about a issue that developed over the weekend.I have a spec stage 3 clutch in my camaro that has only 1500 miles on it.I had the clutch out of my car last month due to engine rebuild so I know the pressure plate and disk are in excellent shape.The problem is when I push my clutch in I get this awful groining and vibration through the pedal and when I let the pedal out it goes away and everything is fine.And if Im driving and goto shift gears it wants to grind it feels like the clutch isnt disengaging.Im thinking its a throwout bearing.Does anybody have any opinions.
Old 10-12-2011, 01:38 PM
Sladester2's Avatar
If it sounds like metal hitting metal it is usually the throw-out bearing. Wouldn't hurt to check you pilot though also.
Old 10-13-2011, 08:45 PM
timespayne's Avatar
Throwout bearing, hopefully no damage to pressure plate.
Old 10-14-2011, 03:02 PM
spike30th's Avatar
Thanks guys I'm going to be pulling the trans out next weekend. Hopefully it's just a throwout bearing I just bought this clutch last spring.
Quick Reply: Throwout bearing???
