Conversion thread for C6 T56 to Fbody
If you are talking about a C6 T56 with a two piece cluster gear, its the same exact thing as the C5 T56 conversion.
If you are talking about the C6 Z06 T56 with a one piece clsuter gear, it's still basically the same thing as a C5 T56 conversion except the bearing in the tail housing has to be addressed like what you have to do with a Viper cluster gear or a T56 Magnum cluster gear.
https://ls1tech.com/forums/manual-tr...ock-parts.html
which was concluded with a very large PDF document:
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
