doesnt want to go into gear
Old 10-31-2011, 06:27 PM
SportGoldSS's Avatar
Default doesnt want to go into gear
I have a 2001 Z28 and im pretty sure the tranny is stock. I put a new kentucky clutch in about 2000 miles ago so it should be good. The problem is when im sitting at idle in neutral, I have to slam it in first gear and the car kind of jerks a little bit when i do. Once i get rolling it starts going a little bit smoother when i rev-match. If im driving rather spirited it starts giving me problems again. Im thinking and hoping its the clutch master cylinder so ill probably go with a tick. But could there be anything else causing this problem.
Old 10-31-2011, 09:43 PM
Jr.Samples's Avatar
Syncors or bad first gear. Does it ever go into 1st smoothly?
Old 11-01-2011, 12:21 AM
it goes into 1st smoothly when im rolling and down shifting when its close to rev matched.
Old 11-01-2011, 10:44 AM
LS1TECH Sponsor
Joey@Tick's Avatar
The first thing I'd do is the easiest thing: make sure the clutch is fully disengaging. An improperly disengaging clutch will always be tough to engage first or reverse with.
A good read on hydraulic shortcomings is here: http://www.tick-performance.com/imag...kshiftfaq.html
..and the solution (our Adjustable Clutch Master Cylinder Kit) is here: http://www.tickperformance.com/tick-...or-ls1-f-body/
Old 11-01-2011, 05:22 PM
SNLPerformance's Avatar
What's the condition of the clutch master cylinder reservoir fluid?
Old 11-01-2011, 06:20 PM
I have noticed the car jerking when I put it in gear and rolling a little bit. The fluid is pretty much new in the res.
Old 11-02-2011, 12:52 PM
If the fluid is clear, full and bled it then it sounds like you have a disengagement issue. A Tick should solve this problem for you whether it's the master or the clutch.
