spec throw out bearing
Old 12-09-2011, 02:10 AM
bbs350z's Avatar
Default spec throw out bearing
i recently picked up a 3+ and didnt have the spec TOB, im still using the factory one. i read that the factory and spec are the same. car has not started or driven yet so im unsure if it will pose a problem, but is the spec TOB a requirement??
Old 12-13-2011, 01:31 PM
SPEC-01's Avatar
It is always best to install a new bearing (and slave too) when installing a new clutch. If there is an issue with the one you have the transmission will have to be removed and this is both time consuming and frustrating.
Old 12-16-2011, 12:26 PM
3rdCoastPowerSports's Avatar
Bearings are cheap in respect to the time and labor to pull the trans
