Prob getting my clutch to bleed
Old 12-09-2011, 06:48 AM
stewdy1's Avatar
Default Prob getting my clutch to bleed
Ok this is my first time to ever mess with a m6, the setup is ls1/t56 in a mustang(real original right lol) ok here is the prob,
I tried bleeding the brakes last night to no avail, there is absolutely no pedal at all. It just goes straight to the floor, I think I made some progress cuz when I first started the pedal would not come back up on it's own, now it is.
I have a general idea on how to bleed it but it just seems I was not getting anywhere with it, so any advice or tips or tricks would be much appreciated
Old 12-09-2011, 02:37 PM
KTK Z28's Avatar
How are you bleeding the system? And what master cylinder are you using?
Old 12-09-2011, 03:16 PM
stewdy1's Avatar
I was doin it just like brakes at first pump pump pump break bleeder then tighten bleeder and repeat
Then I tried opening bleeder then push pedal down and close bleeder while pedal still Down<-<-<- best luck with this method as it took in a bit of fluid from reservoir and made pedal go from sticking on floor to comin back out on it's own
Not sure what master it is, I got the whole setup outta a diff mustang with ls swap, it was working fine in other car
