Monster level 3 after 15,000 miles
Old 12-10-2011, 11:29 AM
SWEET98SS's Avatar
Default Monster level 3 after 15,000 miles
So I am the middle of fixing my low oil pressure problem and pulled the clutch.
Here is my monster level 3 after 15,000 miles, car has 405 rwhp.
Does this look like it is shot? It looks like the rivets are almost going to touch the flywheel. It was squealing upon take off also for the longest time.
Attached Thumbnails Monster level 3 after 15,000 miles-img_0343.jpg   Monster level 3 after 15,000 miles-img_0349.jpg   Monster level 3 after 15,000 miles-img_0352.jpg   Monster level 3 after 15,000 miles-img_0351.jpg
Old 12-10-2011, 01:06 PM
RARON455's Avatar
No, I think it looks pretty good, If you did not put it in yourself,then you may not know the pads on the new clutch disc are really not very thick, they were thinner than I thought they would be when I ran my manual setup.. the flywheel looks good in the pics, I dont see any burning, or hazing, Pressure plate looks great too. From the Pics, everything looks good.Remember before you put it back together spray everything with brake cleaner, and dont touch the clutch, or mating surfaces, You should be good to go.
Old 12-10-2011, 02:21 PM
SWEET98SS's Avatar
I put it in myselft and remember it wasnt that thick. I emailed monster for the new thickness and I will measure it. It would be great if I dont need a new clutch as my engine is in pieces now due to a oil pressure problem.
Old 12-10-2011, 05:13 PM
99 PROBLEMS's Avatar
whats the low oil psi problem? or you haven't figured it out yet? dips to o psi at idle???
Old 12-10-2011, 07:14 PM
studderin's Avatar
moster would know. I know when I had my Rams, they would be like .3xx new. And they told me .280 was the min. When I took mine out it was at .250 and the rivets were starting to touch. Your see heat on the disc.
I think that looks great for 15K miles, you dont ride the clutch. No heat marks at all, I htink you have stock gears with the cam too.
I always have heat marks, but I got to a track a little. haha
Old 12-10-2011, 10:49 PM
SWEET98SS's Avatar
99 problems
My oil problem is at high rpm , it drops to 40 or sometimes 20. All other pressures are normal.
Studderin
I sent an email to monster so I will see what they say. It holds great but the squealing definetely sucks.
Oh yeah, i pulled the motor apart, the valve struck one of the pistons, just put a nick in it.
Old 12-11-2011, 12:03 AM
Hanzy98LS1's Avatar
Mines howlin-squelin on take off or down shifting to.. Ive got maybe 8k on it if thay let you know what it is post it up cuz it sucks...
Old 12-11-2011, 08:15 AM
BADD SS's Avatar
that looks fine.... I ran those clutches for 2 years, thats still good. Measure it with a micrometer.
Old 12-11-2011, 08:24 AM
SWEET98SS's Avatar
I was told the squealin is from slipping it too much, it puts a glaze on it. Steve, owner of monster, sakd to be on it and it will go away, mine never went away even after dropping it like 10 times.
Old 12-11-2011, 11:17 PM
nmass399's Avatar
You still running the stock 10 bolt?
Old 12-12-2011, 05:53 AM
SWEET98SS's Avatar
Yes, stock gear
Old 12-12-2011, 06:44 PM
SWEET98SS's Avatar
So i have the measurements from Steve over at monster, just need to go to harbor freight to get some calipers.
Old 12-17-2011, 02:26 PM
SNLPerformance's Avatar
Dropping it from a stop and blowing the tires off is not what we mean by beating on it. If the tires go up in smoke it does very little to deglaze the clutch.
Old 12-17-2011, 03:35 PM
SWEET98SS's Avatar
I actually do this going 60 mph. Also, side step it in 3 or 4th while going this fast.
