quicktime bellhousing
http://www.jegs.com/i/Quick-Time-Bel...ductId=1293712
says needs 11" or smaller clutch. does this mean the clutch that i have right now: http://www.monsterclutches.com/shop/...y-package.html (12" clutch) won't work?
you can only run the 11" race clutches with the steel bell housings?
are there any other steel bell housings that will work?
I forgot something. I did have to grind a little on the back of the oil pan. Just so the plate would sit flush between the engine and flywheel.
but quicktime bell for the win! fits awesome with only oil pan grinding.
I'm gona get one form RPM with the window, for future clutch upgrades. Right now super happy with the RXT for street/track.
Where did you guys have to grind on the oil pan, and what oil pan do you have? I Know BES has a moroso without the lower bolts. I'm gona keep the stock, with that improved racing baffle I got a few days ago.
