Spec Problem SOLVED!
Spec Problem SOLVED!!
you guys will probably laugh at this one - the problem turned out to be the heat shield on the gas tank and the heat shield on the passenger floor board vibrating and rattleling, i put it on a lift while some one revved it up and both are rattleling and vibrating at 16-2 K, kinda feel like an idiot now, thanks for all the comments and advice!
