flywheel indexing question (quick)
Old 12-13-2011, 08:58 PM
3rdCoastPowerSports's Avatar
Default flywheel indexing question (quick)
i removed the stock flywheel but didn't note or mark the position on the crank. when i install my new stock flywheel can i just line up the locator hole on the flywheel with the locator hole on the crank and bolt it to spec? is that how they originally assembled them?
i looked on my flywheel and couldnt find any weights, it does have a 2 small holes of different depths on one side though.
Old 12-14-2011, 04:03 AM
bww3588's Avatar
I Just lined up the locater holes like you said. I didn't have a problem.
Old 12-14-2011, 09:49 AM
NVR_SPDS's Avatar
Just line up the locator holes, and your good to go!
Old 12-14-2011, 10:59 AM
thank you sir's
