Engagement Teeth too worn?
Old 12-13-2011, 09:50 PM
Macs98Z's Avatar
Default Engagement Teeth too worn?
Hey All,
I am rebuilding my trans and was inspecting all the parts tonight. I am concerned about 2nd, 4th, and 5th gears as there seems to be more wear on the engagement teeth than should be. I would like to get some of your opinions, as I do not have experience in this. The attached pics are in order of the gears, 2, 4, & 5. The engagement teeth are not chipped--it's just the way the light hits certain ones. They are just worn and I'm trying to decide whether I need to replace them. Any help is greatly appreciated. Thanks!
Attached Thumbnails Engagement Teeth too worn?-img_3822.jpg   Engagement Teeth too worn?-img_3821.jpg   Engagement Teeth too worn?-img_3823.jpg
Old 12-13-2011, 10:46 PM
DAVESS02's Avatar
The only thing 2nd is good for is faceplating. 4th should also be replaced and from the pic, appears to have some scoring on the cone face. If you're set on re-using it, I'd put the new blocker on it and measure per the Tremec spec. I wouldnt be surprised if the blocker drops down all the way to the synchro face. Really, since you're there, replace any gear with rounded synchro teeth. No sense in doing it twice.
Old 12-14-2011, 08:34 AM
85MikeTPI's Avatar
Originally Posted by Macs98Z
Hey All,
With new blockers and synchros, they'll be fine..
The best part of rebuilding yourself, if/when they do eventually become a problem, it's nothing but your time to replace them.
Old 12-14-2011, 11:32 AM
TDP
TDP's Avatar
If you aren't going to replace the gears, then at least clean/sharpen the teeth up with a dremel.
Old 12-14-2011, 12:29 PM
85MikeTPI's Avatar
I wouldn't even bother trying to repoint them, that tends to cause more problems than solve unless done correctly. If what's said is correct and there's no chipping, it appears that they'll add a slight resistance to the shift, but the back-taper appears in good condition. It's still a good idea to check the new blocker ring on the cone for engagement. (I like the machinist-dye method)
http://www.rsgear.com/articles/2005_07.pdf
http://www.rsgear.com/articles/2000_03.pdf
If you're running a shop and warranty your work, this would definitely be a case to replace the gears. But if the OP is DIY, these gears can be reused with little to no issue. (When you DIY, you're less likely to complain to your rebuilder about every little thing.. ;-) )
Old 12-14-2011, 12:51 PM
dgcustomz's Avatar
Just a heads up, if you are going to order parts then that second pic is third gear, not fourth. Fourth is on your input shaft. I would trash the 5th gear.
Old 12-14-2011, 01:21 PM
wrd1972's Avatar
IMO that 2nd gear is very questionable and if it were me I would replace it. IMO I would replace anything deemed questionable because I would not want to have to risk having to pull trannys out and take them apart any more than needed.
I recently rebuilt mine and all of the dog teeth on all the gears were perfect but the teeth in the 1st gear sliding syncro ring were rough while the 1st blocker ring teeth were also perfect. I figured the rough syncro ring teeth were accounting for why on occasion, it was very hard to shift into 1st gear when at a stop. Folks on the board also suggested it would be fine to reuse the questionable ring but I did not mind spending the money for a new ring because of the reason illustrated above.
I replaced the 1st gear syncro ring during the rebuild and to this day, it has never once refused to slide easily into 1st gear at a stop.
My 2 cents, replace anything questionable.
Old 12-14-2011, 10:30 PM
Macs98Z's Avatar
Thanks for the replies, guys. If I go ahead and reuse the gears though, will I be causing my new synchros and blocker rings to prematurely wear? I don't want to spend $670 on parts for a stage 2 rebuild and have them wear out faster because of re-using old gears with worn engagement teeth.
And thanks for the articles posted, Mike. There's some really helpful info in there, everybody!
Old 12-14-2011, 10:36 PM
Macs98Z's Avatar
In the pictures it does kinda look like the second pic is third, but it really is fourth. I was holding up the input shaft to the workbench to snap that picture.
Once again guys, thanks for the responses!
Old 12-14-2011, 11:05 PM
DAVESS02's Avatar
On 4th, if the cone is worn to the point where the synchro drops down and bottoms out against the gear, it wont work. I cant remember but I think the spec is about .020 of clearance. If its much less, the blocker wont grip the gear properly and speed match wont occur, causing shift problems. In fact, check every blocker to gear for proper fit.
Old 12-14-2011, 11:34 PM
Macs98Z's Avatar
Thanks, Dave. I actually went back and looked at 4th again and noticed some chipping/fragging on a few of the teeth I had not noticed before. I will probably just go ahead and replace it to be safe. The previous owner had mentioned that he had a 3-4 shift grind, so besides the synchros being shot, this may also be cause for it. If you look closely at that pic, you can also see where it had ground on the gear teeth themselves and started scoring the edges of them.
My next question for you all is, now it seems I will be replacing 4th, I will need to pull the old bearing off and press it on the new input shaft, correct? What's the best way to check and shim for proper endplay on the new shaft? Do I have to put the whole trans back together before I can check with a dial indicator?
Thanks everyone for your replies. They are much appreciated!
Old 12-15-2011, 01:34 AM
DAVESS02's Avatar
Thanks, Dave. I actually went back and looked at 4th again and noticed some chipping/fragging on a few of the teeth I had not noticed before. I will probably just go ahead and replace it to be safe. The previous owner had mentioned that he had a 3-4 shift grind, so besides the synchros being shot, this may also be cause for it. If you look closely at that pic, you can also see where he had ground on the gear teeth themselves and started scoring the edges of them.
4th gear just has a race in it, the bearing is mounted on the output shaft. You dont need to replace it if it isnt bad but if you want the piece of mind, since you're changing the surface it rides on, its an easy swap. I dont know if a race already comes in an input shaft. If not, its critical to make sure you get it driven all the way in the gear before you figure your shim pack. Figuring out your end play will take you some time, just be patient. A dial indicator will work fine. On a loose shaft, as you shim out the front race, you can watch the clearances drop on the endplay and that will educate you to the approximate relationship between X amount of shim = Y amount of end play removed or added. I set my faceplated T-56 up on the tight end of all the specs and its held up great other then a damaged 5th gear key this summer. just read through the tremec manual for end play measurement procedures. Good luck!
Old 03-26-2012, 04:54 PM
Macs98Z's Avatar
Well, it's been a while but I wanted to update this for anyone's reference in the future. I decided to replace 2nd and 5th gears, and leave 4th alone (didn't want to have to fool with endplay, plus at the time I was ordering parts a new input shaft was on a month long back order). I put the trans back together and installed it in the car a few weeks ago. Since that time, I've put quite a few miles driving on it, and everything is great! I can't tell any hard shifting issues going into 4th like I thought I might have. Thanks for everyone's advice and help.
Quick Reply: Engagement Teeth too worn?
