Spec Twin Disk not wanting to go in gear at high rpm, What Causes Clutch Drag???
Old 12-21-2011, 08:20 PM
1Ls1's Avatar
Exclamation Spec Twin Disk not wanting to go in gear at high rpm, What Causes Clutch Drag???
Got a brand new spec twin disk in a 00 trans am, with the correct small shim with tick master bench bleed. Around town cruising it goes in super smooth with 1 finger but as soon as u floor it, gets real hard to go in gear. if you rev the car with the clutch pushed in at about 5-6k rpm, the car moves "creeps forward" was told this is clutch drag..Something's not right. Help appreciated thanks
Old 12-21-2011, 08:21 PM
ANTICOP RAM AIR's Avatar
Originally Posted by 1Ls1
Got a brand new spec twin disk in a 00 trans a, with the correct shim of course with tick master bench bleed. Around town cruising it goes in super smooth with 1 finger but as soon as u floor it, gets real hard to go in gear. Something's not right. Help appreciated thanks
did you change tranny fluid? put in synthetic?
Old 12-22-2011, 12:34 PM
1Ls1's Avatar
yes it was shifting fine with the stock master cylinder and ls7 clutch.
Old 12-29-2011, 02:59 PM
1Ls1's Avatar
nobody knows how to fix clutch drag?
Old 12-29-2011, 04:49 PM
jbridwelltransam's Avatar
I would say you probably need to adjust your tick master a little more.
Old 12-29-2011, 09:58 PM
Nmbr1GMfan's Avatar
If the clutch is dragging and the shim is correct the master needs adjusting.
Old 12-30-2011, 03:40 AM
alecat454's Avatar
Make sure all the air is out of your system. You have to adjust your master per the instructions that tick gives you,
Quick Reply: Spec Twin Disk not wanting to go in gear at high rpm, What Causes Clutch Drag???
