Cluster interchange
Cluster interchange
Do the clusters (1/4 ,5/6) interchange between the single/double cone and the double/triple cone designs? Assuming same tooth count/ratios. I'm guessing the 1/4 cluster should, but not sure about the 5/6 cluster since the main shafts are design specific.
I've got a c5 trans with a trashed input, 1/4 cluster and worn 5/6 cluster. I can get a good used camaro 1/4 cluster and 5/6 cluster cheap to keep rebuild costs down if they'll work. Thanks
M29 / M12 1-4 countershafts interchange regardless of triple/double or double/single.
MN6 1-4 countershafts interchange. regardless of triple/double or double/single.
If you're talking about the 5-6 clustergear on the mainshaft, MN6, M12, M10 are all the same one regardless of double or single.
