problem bleeding after drill mod
Old 12-23-2011, 11:26 PM
Jezzum450's Avatar
Default problem bleeding after drill mod
i did the drill mod on my camaro and i did mostly very thing the site said.
http://www.installuniversity.com/ins...r_cylinder.htm
the only thing i didn't do is pull the hole master cylinder off (thats a Pain) but i drilled the line cleaned it really good then installed it i spent 6 hours bleeding it and the next day about 4 hours with a mityvac it pulled so much air bubbles out even took it to my buddys shop after and spent another 30 min bleeding it the old fashion way and i still have a lazy clutch peddle, i have been doing a lot of research and from what I've been reading its a pain to bleed but i dought it takes as long as it has for me if you guys can give me an ideas on how to go about fixing this it would help out
Old 12-24-2011, 11:21 AM
Turbodude06's Avatar
I'm having the same problem after my drill mod too.
Old 12-28-2011, 03:15 PM
Jezzum450's Avatar
What exactly did you do
Quick Reply: problem bleeding after drill mod
