pedal pressure issue! HELP
My slave cylinder busted. I changed the slave cylinder, master cylinder and replaced the line. Got it all back together. Now that i am trying to bleed. The pedal has no pressure but will come back up after pushing down. When i crack open the bleeder on the trans fluid comes out. I did this 50 times. It still has no pressure but will come back up and fluid comes out of the bleeder valve. I keep fluid filled. Any ideas?
I bought it as a complete package. Line, slave and master cylinder all together from chevy. so i changed it all out. I can try pumping it more but was confused as to why fluid comes out of the bleeder valve but would not build pressure. Pumped prob. 50-60 times.
you're gonna have to get a hand held vacuum pump and bleed it through the resevoir.thats what i did,there are numerous writeups about it.did you search?i tried to get my pedal pressure back.it wouldn't come back.so i researched my problem and this was my solution.
I am going to buy the mity vac this weekend. Where can i find instructions on how to use it properly? Thanks
