Just bought an 02 Z28 M6 - Questions about the clutch
Hey guys, first post here. About 2 weeks ago, I purchased a 2002 Z28 Camaro with about 20k miles. It's an M6. I'm curious about other people's experiences with the stock clutch. I've driven a stick since I was 16 years old (26 now) and never had any problems driving smooth or engaging gears properly. However, I'm having a hard time with this car. I'm curious if those of you with an M6 LS1 f-body have the same experience or if this sounds like a problem with the car.
When I'm at speed and push down on the clutch to shift gears, rather than the car smoothly coming out of gear, the car often bucks slightly and makes a slight pop or thud sound - sounds like cocking a shotgun. I also find I have to be SUPER precise when releasing the clutch/giving gas going back in to gear or else the car bucks again. So, it usually bucks a little coming out of gear and bucks a little when I release the clutch to put it back in gear - makes for an unpleasant drive for myself and passengers. It isn't a loud sound and it doesn't buck wildly, but it's just enough to make controlling the car between shifts difficult. Is this just how these cars drive? Or does this sound like a problem? I've searched repeatedly in these forums and haven't seen anyone with quite this same set of issues. Any insight would be appreciated.
Anybody? Does this mean none of you have experienced what I'm talking about? Or does this mean what I'm describing is totally normal and no one has the heart to call me an idiot?
Forgot to add: No clutch slipping issues, but 2nd and 4th are pretty notchy.
djfury05, not yet. I actually have an appointment to have the clutch, trans and brake fluid swapped out next weekend. Does your SS do this at all or is it rock solid? It almost feels like there is some slack in the drivetrain that is just kinda slopping around between shifts, if that makes sense.
Actually just came across this thread, seems a number of people have this problem:
https://ls1tech.com/forums/manual-tr...ng-clutch.html
However, no one in that thread seems to have any idea what to do about it.
Anyone else have any suggestions? I'll post my results of the fluid swap next weekend after it's done.
S8ER95Z, have you ever experienced the issue I'm talking about? Ever have a clunk or drivetrain motion when you push the clutch down? Or is yours always super smooth?
Always super smooth everytime.. I did start having rough issues when the slave was leaking. You can look under the car to see if any fluid comes out of the trans case after pumping the clutch a few times.
It's also possible that the car has an aftermarket clutch in it. I avoided going aftermarket because of 'chatter' and complaints about rough engagements. Until I need something better the car will keep getting own LS6 clutches (which your 02 would have come with from the factory).
I'm about 99.9% sure the clutch is stock. The car has only 21k miles and was totally bone stock when I purchased it. I would be real surprised if someone swapped out an aftermarket clutch at those miles with no lid, exhaust or anything else at all modified. I've driven other stock LS1's and this feels pretty much identical. Very light pedal, very "loosey goosey" clutch for the masses type feeling - unlike the solid, heavy pedal feel of other aftermarket clutches I've used. I could be wrong, but I would be blown away if it ends up not being stock.
Shifter seems just fine - no odd vibration and feels solid in gear. Goes into 1st/3rd/5th/Reverse easily but 2nd and 4th do seem to grind a tad going in. I had also considered transmission mounts, but in the thread I linked towards the top, a few people tried transmission mounts for the same issue and didn't have any luck. I also tried the trick I've seen referenced in other threads to see if the clutch is "catching" - I put it in first and revved to redline with my foot on the clutch, but the car never moved an inch.
I've had the same problem. Coincidentally, I have an 02 Z28 M6 that I bought last April with just under 20K miles on it. The guy I bought it from averaged about 2K miles/year on it. He sent me a list of mods that he could remember, and aftermarket clutch wasn't one of them, so I'm guessing it's stock. But yeah, every time I get behind the wheel, it feels like I have to re-learn how to drive a stick. People behind me literally honk their horns sometimes. So let me know what you find out; I'd love to know what's causing it.
Saharper, have you tried replacing the fluid? From searching the forums, it seems like a lot of the stupid issues I'm having with this car are also had by people that have 20-30k miles on these cars. I imagine because these low mileage cars sit for so long, we are likely going to have to replace a number of parts that were intended to have fresh fluid running through them on a regular basis. I'll update again when I replace the slave/master.
Thanks for the update. Yeah, just had the fluid replaced this weekend. Didn't switch to synthetic, but the flush seems to have helped a bit. Feels like there's air in the line, so won't be able to tell for sure until I get that straightened out.
I agree. This unfortunately probably won't be the last issue we deal with, but hopefully they'll require mostly minor fixes. Let's hope, at least.
Updating old threads: Tick Master cylinder just completely fixed this problem - and improves the way the car shifts by 10 fold. Literally. It feels more like shifting a newer G37 now as opposed to a 10 year old clunker! If you are wondering if it's worth the $325, the answer is YES.
