Really dumb pedal question
Which way is the clutch return spring supposed to apply pressure. If un hooked from the master cylinder, should the pedal go up or down??? I can't figure out how to install this damn spring and yes I've read all the threads. Thanks.
Ok, great. Cause that's what I was finding with the way I installed the spring. It was pulling the pedal up and then it would also pull the pedal down once it reached a certain point in it's swing.
One more question tho, does anyone know where I can get the center white plastic "U" shaped bushing? My local GM dealer says there is no such thing???WTF? And I can't find it online anywhere.
have your dealer do a dealer locate to see if any are available nation wide. they are still available i think i got mine thru dealer a year ago. don't knoe from where he got it but i got it try the after market catalogs good luck!
