Clutch Adjustment
What clutch and flywheel did you go with? Was the flywheel new or resurfaced? How much? Did you install new hydraulics when you replaced the clutch? If the hydraulics are in good condition and well bleed sounds like you need a shim behind the slave cylinder.
