Clutch Pedal Sticks To Floor??
2002 ws6 40,000 miles m-6. 471 rwhp I can shift into any gear as long as I am not full throttle on the gas pedal. As soon as I get on it, first to second is fine but it only goes into third every now and then and if you get it into thrid, you will not go to fourth. The pedal sticks to the floor and I have to pull it up with my toes and pump the pedal to get restriction back. I have pulled the tranny and changed the slave cylinder and also installd a Tick Performance master clutch cylinder. It is still doing the same thing. HELP ME. I need to go to the track and see what full potential this car has...
I had this same problem with my 00 SS. it had 100K miles on it. IT worked great during normal driving but when i raced it it would stick when i was going into 4th. and it was the rear main seal on the motor leaking onto the clutch . as soon as i got all that fixed it stopped doing that. just my 2 cents . hope that helps
have the same problem , i have changed fluid many time, i have new master cylinder and slave but the slave is a rebuilt i think, i have a stock 1999 pressure plate, fidanza aluminium flywheel , and a ceramic 6 puck disk i am very tires of this problem il think to switch to the katech twin disk clutch.
