What to use to clean clutch with?
Old 02-05-2012, 08:13 PM
703 CAMAROSS's Avatar
Default What to use to clean clutch with?
What do you use to clean grease and oil of the fly wheel, clutch disk, and pressure plate? Do you just use brake clean and a rag? Or is there a special clutch cleaner?
Old 02-05-2012, 08:44 PM
JaYZeig's Avatar
usualy if the clutch disc is contaminated with oil you SHOULD technically replace it, because its only going to fail, but if its surface oil from greasy fingers im sure youll be ok, youll be fine to just use brake clean.
Old 02-05-2012, 08:49 PM
I don't know if the clutch disk has oil or not it was in the same bag as the fly wheel and pressure plate. It's used with 500 miles
Old 02-05-2012, 08:50 PM
Fly wheel and pressure plate had grease
Old 02-05-2012, 09:06 PM
JaYZeig's Avatar
well i juss say to try brake cleaning everything, and after the brake clean dries on the clutch disc, examine it closly to see if you can see any more grease/oil on it. im sure it would look spotty where the grease is.
Old 02-06-2012, 03:24 PM
SPEC-01's Avatar
Spray the parts down with brake-clean and then wipe them down with a towel to help remove the contamination. This may need to be done repeatedly. Keep in mind that if you are using an Organic or Kevlar lined disc that cleaning will not actually resolve the issue. These materials are pourous and they absorb grease and oil which means that the contaminant will simply resurface when the disc gets hot. As a result, the disc may need to be replaced. Let me know if you have any further questions. Thanks,
Old 02-06-2012, 07:31 PM
This may sound stupid but could I bake the disk in an oven at like 75 degrees or something maybe 100 and then make the oil surface and wipe it down?
Old 02-07-2012, 12:17 PM
SPEC-01's Avatar
No, because it will be impossible to fully remove the contaminant from the surface. Even a drop, or a few drops, will impact friction coefficient and performance of the clutch.
Old 02-07-2012, 08:54 PM
Tough Mudder
Hilton's Avatar
Maybe buy a new disk or have the pads replaced on the disk you have already?
Old 02-08-2012, 01:10 PM
SPEC-01's Avatar
That is an option dependent on the condition of the other components.
Old 02-10-2012, 11:58 AM
My clutch is sintered iron. So i think it should clean right off with brake clean.
Old 02-10-2012, 12:18 PM
SPEC-01's Avatar
It should...and make sure to clean the plate and flywheel surfaces too!
Old 02-10-2012, 12:42 PM
Thanks allot everyone
Quick Reply: What to use to clean clutch with?
