clutch pedal bushing, see pic
Does anyone know where I can get one of these white "U" shaped bushings? My GM dealer says the part doesn't exist, WTF??, and I can't find it online anywhere. I also need the 2 white bushings for the springs, but I think I found something that will work.
Thanks, Spartan7, for the pic.
try hawksthirdgen.com they have every part you can think of bro give them a call or look on there website. quick question im one part away from doing the t56 swap on my CETA what are the white switchs over the clutch and the two over brake pedal?
I've tried Hawks, but I'll check again.
The switches above the brake are for the tail lights and the other is for the torque converter switch/cruise control. The one on top the clutch pedal is the clutch anticipate switch. It "flares" up the engine prior to changing gears. These need to be wired together when doing the swap.
