Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Manual Transmission
Sign in using an external account
Register Forgot Password?
Manual Transmission
T56 | T5 | MN12 | Clutches | Hydraulics | Shifters
Sponsored by
McLeod Clutch
Thread Tools Search this Thread
Old 02-18-2012, 04:26 AM   #1
Garage is empty, add now
Trader Rating: 0
Default Problems after reinstalling my built T-56
Well, I had my T56 out of my 1995 Trans Am. When I got it back in the car I had some odd problems. After a few pushes of the clutch pedal it would become hard. I figured that I didn't align the slave right(lt1) so I took it off and found the clutch fork had popped out of place. I put it back and reassembled everything and it felt a little better for a little while only to have the same thing happen. I took it apart again and thought I had fixed it. When I went for a test drive the clutch was slipping like crazy and then the hydraulics failed again and I couldnt put it in a gear. So I turned it off and started the car in first and limped it back.
Any clue what would cause this?
Leftoverchinese is offline   Reply With Quote
Old 02-18-2012, 10:16 AM   #2
jmd
Trader Rating: 4
If it's hard it's possible the fluid can't flow back up to the reservoir. This can be due to the master being held pushed in.
To what torque rating did you tighten the pressure plate bolts?
__________________
Matthew
jmd is online now   Reply With Quote
Old 02-18-2012, 11:42 AM   #3
Trader Rating: 0
I didn't remove the clutch, only the transmission.
Old 02-21-2012, 12:03 AM   #4
Trader Rating: 0
Well, we just pulled the transmission again and we haven't quite solved it yet. We thought it was the spring on the fork so we did our best to tighten that, but to no avail. There seems to be play in the throw out bearing but we don't know if that necessarily means that it's bad. It may be well within the expected tolerances. Tell me what you think.
Old 02-21-2012, 11:26 AM   #5
Trader Rating: 0
No one knows if that's bad or not???
Old 02-21-2012, 04:10 PM   #6
Trader Rating: 0
Jeremy from Spec saw the video and says that the bearing is fine. He thinks we may have had the orientation of the bearing wrong. If that's not it then my fork may need to be replaced.
Old 02-22-2012, 01:30 PM   #7
LS1Tech Sponsor
Trader Rating: 0
As mentioned you can think of the bearing as a baseball diamond. The bearing needs to be oriented so that the fork is contacting/pulling on the Home Plate and Second Base locations. If the fork is pulling on the "baseline" sides then it will popout. Some movement is normal, and the video provided doesn't appear to evidence extreme amounts of movement. All this being said, do you know if the bearing was aligned in the way I mentioned? If you wish to order a new bearing give me a call and I will be happy to help you with one. Thanks!
__________________
J. Auvil
Sales and Tech Manager
SPEC, Inc.
800-828-4379 x.109
Jeremy@specclutch.com
SPEC-01 is offline   Reply With Quote
Old 02-23-2012, 02:26 AM   #8
Trader Rating: 0
Thanks, man. I don't think I had it angled incorrectly, but it's possible. I have a new fork, pivot and bolt on their way just in case. Hopefully this will be the end of my problems. My pivot on my tranny is pretty worn so it can only improve things.
Old 02-26-2012, 05:44 AM   #9
Trader Rating: 0
I replaced the clutch fork, pivot, and screw and it worked perfectly. So I'd say that was the issue.
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
clutch, fork, hard, lt1, pedal, popped, replacement, slave
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
