Difference between some T56 trannys -need to know before I buy
I've tried to google/search but haven't really come across what I am looking for.
I have an LQ4 that I am rebuilding/LS3 top end. I cam across some local adds for a T56. There is a guy who has both a C5 and C6 transmission, but someone told me these are mounted in the rear? So the pictures look different then what I am use to seeing a t56 look like.
Does it just need a bellhousing and some unit that has the shifter over the output shaft to convert it into a normal t56 that I can use (along with the proper clutch/spacers/flywheel and what ever else I need) ???
I found the following 3, are any of these going to work for my application?
2005 c6 tranny (50K) 1000$
2006 c6 tranny (22K on it) $unknown
freshly rebuilt c5 z06 tranny (waiting on year) $unknown
I remember reading the 00-02 f-body if I could find complete would work best for me?
Thanks, and sorry for being a noob
LS1 mid plate $160ish
Fbody main shift rail $40ish
Fbody shift selector arm $45ish
GTO main shaft $200ish
Fbody tail housing $200ish
VSS wheel $25ish
Labor $250-$350ish
Thats providing you need nothing else when it is torn down and if you have it done locally so you have no shipping cost incurred.
http://www.tickperformance.com/1993-...camaro-trans-am/
