Tick master rod loose?
Hello,
I have a tick master on my car, new slave, ls7 clutch setup and pro 5.0 shifter on my car. I have adjusted my master twice so far. The first time the car shifted great, but after driving about 100 miles, the car was hard to get into gear again. I have adjusted the master again, it is easy to get into gear, and doesn't move when taken to redline. I believe the problem is the adjustment rod is loose. I have tightened up both nuts at either side of the rod and I can still turn the rod with my fingers. I think that this is causing the clutch to need adjustment after driving. Any help would be greatly appreciated.
Thanks,
Travis
Thanks,
Travis
Hello,
Thanks,
Travis
Thanks,
Travis
