rod from pedal to master snapped
the other day, i press the clutch pedal to start the car and it fell to the floor, i pulled it up and couldnt press it down again...
my friend force it down, but the pedal stayed down.
i go under the car and the the clutch line popped out of the slave.
i put it back in and proceed to bleed, then notice pedal is either down or up.
go to check..
and rod is broken ???
for the **** of it i got a new slave and will be ordering a tick..
what do you think went?
the slave and then in the process to force the pedal down, the master snapped?
slave has maybe 25k on it, master has 106k
go to check..
go to check..
go to check..
http://www.tickperformance.com/categ...rt=bestselling
