Hydraulic line to master cylinder fitting?
Old 02-21-2012, 10:24 AM
Ferocity02's Avatar
Default Hydraulic line to master cylinder fitting?
Anyone know what kind of fitting this is? I'm doing a T56 swap into the truck and the truck master came with a short hydraulic line, about 20" long, it won't reach the normal F-body slave. I'd like to do my own -3 hydraulic line if possible. I found the Russel fittings (640281) to connect the -3 to the slave.
What fitting is needed to connect the -3 to the master?
Thanks!
Old 02-21-2012, 10:29 AM
Ferocity02's Avatar
Looks like the Russel fittings thread straight into the master and straight into the slave, eliminating the quick disconnect fitting. Is this correct?
Quick Reply: Hydraulic line to master cylinder fitting?
