Odd T56 problem (03 Z06)
If I start out in first gear it sometimes gets stuck in first and takes a little play to get it out. When I do get it out. I shift to second which majority of the time will grind or pop out. Other times if I start out in first and then go back to neutral the clutch is still engaged. Takes me a few tried of pushing clutch in and changing gears to get it out of its engaged state. Now when I start in second gear (have been doing this for the past 3 weeks) I have 0 problems. It's only when I start off in first that I have a high chance of it giving me problems. I changed the fluid and it did nothing. Car has 75K miles on it. Clutch is giving me 0 problems. Doesn't slip, don't have the pedal stuck to floor, etc. Any ideas?
