1999 camaro trans help
So I dropped the trans a few days ago on my z28 because I beloved it has a bent shift fork. I'm going to put a 30 spline viper shaft in with a few other parts to make it shift better, but I had a few questions.
Since I'm in there I'm going to do a clutch, once I put a strong one in there what is going to be the first thing to go out? Driveshaft or rear end?
Ok sweet I will be running on stock power for a while so I should be ok. When I do the 30 spline conversion to the trans is there anything I need to do to the out put shaft of the motor?
As far as the tranny build goes. The 30 spline Viper shaft is one of the best options for the T56, however, make sure you replace a lot of other key elements or you will essentially create another weak link in your T56.
Here is a link to our T56 builds that you may want to invest in: http://www.tickperformance.com/1993-...camaro-trans-am/
