T56 is apart, what to replace... with some pics
I bought a used T56 out of an '01 Z28 with 80k miles. Shifted well according to the owner but I took it with a grain of salt. This tranny will be going into an '01 Silverado 5.3L extended cab which will be boosted soon, looking for 500+rwhp.
I finally got the T56 all apart and for the most part it looks okay. There was no excess metal on the magnets, all bearings look great and move smoothly, no chips in any gear teeth, no unusual gear wear.
The only damaged part I found were the fork pads on the 1/2 fork (I think, could be 3/4).
Broken tooth on the 3/4 blocker ring, which might have been my fault.
The synchro sleeve/out housing teeth for 1/2 and 3/4 look fairly worn too.
And the synchro teeth on 2nd gear are pretty worn, see pics. Worth replacing?
I was thinking of doing the stage 2 rebuild kit from The Gear Box, or maybe just the basic kit. After buying all the other parts needed for the swap I am low on cash, so I'm leaning towards the basic kit.
Thanks for the help.
1/2 synchro sleeve
Reverse blocker
3/4 fork pads
2nd gear
2nd gear
2nd gear
3/4 blocker
3/4 synchro sleeve
1/2 synchro sleeve
Reverse blocker
3/4 fork pads
2nd gear
2nd gear
2nd gear
3/4 blocker
3/4 synchro sleeve
Still kind of hard to make out the real condition of the dog teeth on those photos but it looks like many are in rough condition. That said if they appear to be blunted or the points are worn off, they are candidates to be replaced.
Recently when I rebuilt my T56, the dog teeth on all of the gears were perfect, not a bit of wear since I am not a big gear banger. However there was light wear of the dog teeth on the 1/2 syncro ring and that caused the issue of not wanting to easily shift into 1st gear when sitting still like at a light. Once this was replaced and the tranny was done, the problem was completely gone.
Since you are doing your own rebuild and saving bucks, dont be shy about replacing questionable parts especially since you like to bang gears as evidenced by looking at your fork pads. Wow. Its no fun to have to go back into it casue you skimped.
Also dont forget to check the fitment of the 5/6 driven cluster gear. If you had to pull it off with a puller, your good. If it easily slipped off the main shaft by hand, you just found another worn gear and possibly a worn main shaft.
You said I like to bang gears as evidenced by looking at my fork pads. I was just saying that the previous owner did that, not me.
I'll go through the parts again and see what needs replacing. I can't afford to do the stage 2 build and replace gears. Thanks for the help.
http://www.tick-performance.com/tick...body/t56parts/
