tick perfomance
you dont NEED to, it makes it easier to bleed the whole system if you bench bleed the master.
i didnt bench bleed my tick master when i installed, instead i let it gravity bleed for a lil while, then i just kept pumping the clutch pedal, and crackin the bleeder open until i got good fluid flow.
