output shaft seal
Old 02-25-2012, 01:14 PM
SilverSS07's Avatar
Default output shaft seal
Hey guys I'm trying to replace the output shaft seal on my 1995 ta t56. I got a seal from advance auto that was too big and didn't fit. Ran the #s on the old seal and got that same seal and now I can't get it to go in. It's part #710441 from carquest. I searched on here and found a thread on here that national part # 710426 was the right part. I got that and it went in properly. Now I can't get the driveshaft in. I know that the one I pit in had a slightly smaller inside diameter than the one that was in. Could it just be too small? Any idea why the other seal was in it? It's not listed for a t56. I just need to get it together I've gotta work tomorrow!
Old 02-25-2012, 07:27 PM
SilverSS07's Avatar
Well finally got the driveshaft in. I used the seal 710426 and cut a lot of the boot off. Driveshaft was getting caught on the boot and for whatever reason couldn't get past it.
Old 02-26-2012, 04:08 PM
hot93rod's Avatar
hmm, let me know how that worked out for you. I have a leaky one, and every time i replace it (twice) i went through a hassle of finding the right one that actually fits... but it still seeps out around the driveshaft (at the boot)... drives me crazy!
Old 02-26-2012, 09:41 PM
SilverSS07's Avatar
I'm taking it down to get painted tomorrow so I'll check it when I drop it off and see if anything is leaking yet.
Old 02-27-2012, 06:56 PM
SilverSS07's Avatar
So far so good . Won't really know more until I get more miles on it.
Old 02-28-2012, 03:46 PM
gconnoyer's Avatar
If you need a new one I suggest ordering one from Tick.
They're like $9 and the exact same part that the dealership has them for $54.
Old 02-28-2012, 04:08 PM
thesource's Avatar
I use a seal without a boot and have never ever had an issue with them. It's a red coated steel cased seal from National.
Quick Reply: output shaft seal
