Stock Replacement Trans Mount
Old 03-08-2012, 07:36 AM
OldCobraGuy's Avatar
My question is why are you breaking them?
Keep in mind...that whatever force is breaking them will now be transferred to the extension housing with a poly mount. Guess what will break next?
Old 03-08-2012, 08:25 AM
Rare96LT1Formula's Avatar
Originally Posted by HoLLo
Do NOT be afraid to use a poly transmission mount. Everyone complains about them and takes them off. You must drive them for a few weeks, and then the vibrations will be completely gone. It will soften up. I've used 3 different poly trans mounts in daily drivers, all on stock rubber motor mounts, and all noise and vibrations go away after a bit of driving. They definitely hold the shifter in place a whole lot better. Most people feel the vibes on day 1 and take them out, but you gotta give it time. Trust me.
/Thread
Too many people install the poly mount, decide they hate it, uninstall it, then come on here and bash it.
Old 03-08-2012, 02:45 PM
VincesSS's Avatar
The nitrous launches on m/t dr's broke it.
And it's far from a certainty that the tailshaft housing would break, certainly not with any of the wopping high 1.6 or 1.7 60ft launches I rarely make.
Old 03-09-2012, 08:34 AM
Originally Posted by jsmith564
it's not a piece of metal... it's rubber. it has SOME give
No...it's poly urethane and it is basically a solid mount. The vibrations it transfers would make a cheap ***** smile.
Old 03-09-2012, 08:38 AM
Well, I had it for a year before I took it off. I think I gave it more than a fair chance. I'm not bashing it, I just just doesn't have any place on my street car!
Old 03-12-2012, 06:55 AM
sheaadams86's Avatar
I have energy suspension trans mount, I had bad vibrations right away and it was just bad motor mounts replaced those with prothane and the vibration almost completely gone, also I didn't use plate and I grinded down the 2 bumps on trans mount first, snugger fit less vibrations, oh and weird thing I had a decent oil before I changed both and now it stopped leaking haha
Old 03-20-2012, 09:48 PM
pkozera's Avatar
Just a heads up why doesnt es offer a specific poly mnt for these cars anyway just a thought.
Old 03-21-2012, 10:38 AM
I also think anything you can do to get that torque arm off the trans is a HUGE plus...but that's an altogether different discussion...
Old 03-24-2012, 10:53 PM
05lactruck's Avatar
Ive never had luck with the poly ones.
Old 03-24-2012, 10:54 PM
05lactruck's Avatar
Why would it be better to have the torque arm off the trans?
Old 03-25-2012, 10:10 AM
I would like to see that torque away from the transmission housing and transferred to the body instead.
Old 04-03-2012, 12:52 AM
  #32
Onyx_Black_Z28's Avatar
I'm going to tell you a little story.
When I installed the Kooks 1 7/8 tubes on my F body, I installed poly motor mounts. It was felt that Kooks tucks their tubes close enough that you should use poly motor mounts to keep them from touching the body when torqued. When I see how close they were, I agreed. Fantastic fit and ground clearance. While I was at it, I also changed to a poly trans mount. When I was done, the vibration inside the car was very noticeable. In fact, it was unpleasant. Enough so that I considered going back to normal motor mounts and putting up with some exhaust clunks. Then I read here where poly trans mounts were a bad idea because they could break the trans extension housing. So I did some searching and found a brand new GM trans mount on Amazon of all places for $47!!! Part # 22174970. It may fit both AT and MT...but I'm not sure. Regardless, it showed up and was a true GM mount. I stuck it in the car and I was totally blown away. The car drove like a brand new vehicle!!! ALL the vibration was GONE! If someone had told me that a simple trans mount would make such a difference, I would have called BS...but it is the absolute truth. I think you can find other testaments here as well.
Do NOT use a poly trans mount!
You sir are awesome - thanks for the tip about the Amazon part number for that transmission mount!!
Old 04-03-2012, 06:14 AM
  #33
99'CajunFirehawk157's Avatar
Thumbs up
I bought that exact same mount from AMAZON, it is a real gm part too, highly recommend.
Old 04-03-2012, 07:22 AM
  #34
ls1ya's Avatar
Get the poly mount. Vibration isn't that bad. if your worried about vibration you shouldn't drive a Camaro.
Old 04-03-2012, 09:12 AM
  #35
Originally Posted by ls1ya
...if your worried about vibration you shouldn't drive a Camaro.
Now that's funny!
Quick Reply: Stock Replacement Trans Mount
