Well this sucks.
Well this sucks.
I just bought my 98 Z28, the guy said "fresh engine and new transmission!". Well i was modest on the test drive and drove it easy. That was my mistake!
A few days of babying it after work i decide to see what shes got... Shift into 1st and gave her some gas.. then i shift into 2nd and thought this is fun!, big smile on my face!
Shift into 3rd... SCRATCH! My smile falls off.. then I shift into 4th and once again SCRATCHES! Im depressed at this point.. then i shift into 5th..SCRATCH.. and then 6th scratched as well.
I thought.. well maybe my clutch is having disengagment issues.. so i replaced the master cylinder and flushed/bled the old black fluid out. The pedal became more firm. But... the issue remains.
Apparently, the gears only scratch if i shift fast.. if i shift like a grandma.. everything is good. None of the gears pop out.. they just scratch when I shift fast.. dosent matter if im at 2000RPM or 6000rpm.
I texted the guy i bought the car from and he swears up and down that the transmission has never grinded for him! Well im pissed at this point... as anyone would be.
Does anyone have any thought of whats next? Im thinking rebuild
If you have verified that the clutch is releasing properly the only real option left is a transmission issue. I would say your trans probably needs a rebuild with new synchro rings and possibly a few gears and synchronizer assemblies. Our basic rebuild package is $645.00 plus shipping and plus any gears or synchro assembles. We won't have any way of knowing the full extent of the damage till the transmission is torn down and inspected. If you have any questions at all feel free to shoot me a PM or give me a call.
Tick Performance T56 Builds for your 98-02 Fbody
Well in a strange turn of events... the problem has changed.
I noticed my clutch was starting to feel spongey so I re-bled the hydraulics. Alot of air came out of the system. The pedal is a whole lot more firm than it ever has been before. Now every gear is very smooth. Going WOT and shifting fast, 4th gear still scratches, but EVERY other gear is smooth now.
How strange is that? What are my options now? Should I drain the trans fluid and refill with detron3?
Very Strange. Your "scratching" going to forth could still be the synchronizer the teeth may just be a little worn. However if the fluid change helped it out that is awesome!! A Tick Master Cylinder would help your high rpm shifts .
Anyway, I drained the fluid last night and it came out brown with glittery sparkles so it definetely has some wear! After I drained and refilled the fluid the problems is now worse than ever, it grinds all gears again besides 1st and 2nd... Im just going to bite the bullet and do a rebuild.
Yea that seems like it maybe your best option to just go ahead and do a rebuild, that way one can see exactly what is wrong when it is torn down. After all if it is something broken flying around inside the trans it can cause a lot of damage to the rest of the internals.
As far as the clutch masters, no sale coming anytime soon.
I think I am having the same issues as you. It only gets hard to shift when I am gunning it. But when I drive like I am trying to save gas, shifts fine. What did you end up doing or find out? If you had to get it rebuilt, where did you send it and what was the estimated cost? Thanks
Tick Performance Adjustable Clutch Master Cylinder
As Far as rebuilds, we do thousands of T56 Rebuilds for all power levels!! Check out some of our rebuilds:
Tick Performance T56 Rebuilds for Your 93-02 Fbody
I went ahead and dissasembled the trans myself.. so far I found that the bearings in the stock pilot bearing self destoryed themselves and wore deep groves in the snout of the input shaft.
Oh and btw... the trans is NOT new. It was covered in oil from a rear main seal leak and the clutch is very worn. Probably the stock clutch. trans dosent look like its ever been apart.
