shifter question
Old 03-11-2012, 10:28 AM
mikh338's Avatar
Default shifter question
hey guys, i wanna cut down my shifter handle an inch or so and I need to re-thread it after. I read that our thread size is 16mm x 1.5? I went to a couple hardware stores to try to find a nut to thread on so after I cut the handle down it will thread back off and clean up the threads. Any ideas? I even went to advance auto etc...
Old 03-11-2012, 11:15 AM
Deviant LS1's Avatar
You need to find store that does nothing but sell nuts, bolts and fasteners.
Old 03-11-2012, 12:48 PM
mikh338's Avatar
yeah the biggest i can find in metric anywhere right now is 12mm. i am correct that its 16mm x 1.5 right?
Old 03-12-2012, 11:28 AM
Save the manuals!
wssix99's Avatar
You'd need to go to a place like Fasenall or Grainger to get a die to do that.
Why don't you just buy a short stick? It will be bent appropriately for the new geometry of the stick and will cost you less money than a threading tool.
Old 03-12-2012, 12:05 PM
mikh338's Avatar
because I can spend $1 on a nut that i just thread on to shifter then cut the shifter down, and thread it back off to clean the threads up. not worth $25 for the short stick. i have a pro5.0 in it now, ijust put a white hurst cue ball **** on it so it needs to be shortened a tad.
Old 03-12-2012, 03:29 PM
Save the manuals!
wssix99's Avatar
If you can thread a hardened steel shaft with a (relatively soft) nut, I'd love to see that. When you went to Advance, did you look for lugnuts in the correct size? That's probably the least expensive way to go. A store that carries regular nuts will charge you for a box of them, which would be almost expensive as a short handle. If you can get a nut, please post back with pics of the results.
Life will probably be better for you if you get the proper die: http://www.amazon.com/16mm-Carbon-St.../dp/B0007CNJ1S
Old 03-12-2012, 03:58 PM
mikh338's Avatar
thanks for the link...yes ive done it before, a few times actually
Quick Reply: shifter question
