Shiming your Clutch
Old 03-15-2012, 02:33 PM
Sales@Tick's Avatar
Default Shiming your Clutch
This Shim Diagram might be a help for some of us visual learners.
Once you've got your two measurements, make sure that your "EQUALS BEARING CLEARANCE DISTANCE" (from the Diagram) is ~1/16" (or .0625) to 1/8" (or .125). Measurement "A" should be bigger than "B". If you come up with more than 1/8" (or .125), add an appropriately sized shim between the slave and the transmission in order to get the measurements where they need to be.
If there is no difference between the two measurements, or if "B" is greater than "A", there could be a problem with clutch engagement which could result in premature clutch slip and eventually a total failure.
Here are some links to our shims:
Tick Performance Slave Cylinder Shim (.055")
Tick Performance Slave Cylinder Shim (.113")
Tick Performance Slave Cylinder Shim (.180")
Tick Performance Slave Cylinder Shim Kit (3 Pack)
Old 03-15-2012, 05:43 PM
Deviant LS1's Avatar
This makes it so much easier to understand. Good job guys!
Old 03-16-2012, 08:37 AM
Sales@Tick's Avatar
Thanks bud! It made it easier for me seeing this my first time!
Old 03-17-2012, 10:25 AM
30th t/a's Avatar
Im a visual learner and this definatley helps! thanks
Old 03-18-2012, 02:58 AM
The Scammer Hammer
dr_whigham's Avatar
I'm a visual guy too..... and am still lost as hell.
Quick Reply: Shiming your Clutch
