Need help with a screw up
Old 03-19-2012, 08:51 PM
00ZNewb's Avatar
Default Need help with a screw up
So apparently my new swanky lightweight flywheel i was so excited about getting was a bad move. It slowed my car noticably. I have a stock motor, no bolt ons yet. I've done all the free mods i could find. What would be a remedy to this flywheel issue (barring swapping back to stock)? i guess im looking for the biggest bang for the money ( wich isnt real plentiful atm)
Thanks much
Old 03-20-2012, 04:43 PM
SPEC-01's Avatar
A lighter weight flywheel (or any lighter rotational components for that matter) will affect the way that torque is applied by changing inertia. This is most noticible at low RPM. That being said the easiest recommendation is to simply add RPM when leaving/launching to counteract this. Let me know if you have any further questions. Thanks!
Quick Reply: Need help with a screw up
