Tick Speedbleeder - Drop Trans without bellhousing?
Old 03-23-2012, 05:49 PM
Ryan 97 Ram Air T/A's Avatar
Default Tick Speedbleeder - Drop Trans without bellhousing?
I'm getting ready to install a Tick Master and speedbleeder on my 99 and am not familiar LS clutch slave cylinder/throwout setup at all.
Been working on my 97 for a decade so I know how difficult it is to get to the engine-bellhousing bolts. Would it be possible to install the speedbleader by removing the transmission and leaving the bellhousing/clutch attached to the engine? If so, would this be the easier or harder way - keep in mind I won't be using a lift.
Old 03-23-2012, 05:54 PM
Average_Joe's Avatar
Yes, its a lot easier that way. Make sure you change that slave too
Quick Reply: Tick Speedbleeder - Drop Trans without bellhousing?
