Spec Stage 1 or LS7 clutch
I just recently picked up another LS1 after being out of the game for a while and what do you know I'm already having issues.
The pedal is sticking to the floor and tomorrow I plan on going through the process of figuring out what the issue is. I already tried bleeding the lines but the pedal still doesn't retain pressure. Next on the list is to check out the master cylinder then slave. If it gets all the way to the slave I plan on just replacing the clutch while I'm at it.
Which clutch would be better for an almost stock 02 ws6 (slp lid and catback exhaust)? I plan to do a cam swap and full exhaust at some point down the road, most likely atleast 6 months out. But nothing more.
Looking for those with experience with either or both and which they think is better especially for the price.
SPEC Stage 1...no doubt. It has greater capacity, it eliminates the stock SAC-ratcheting plate design (which can and often does misadjust and lead to improper release and actuation), and it offers greater consistency and durability too!
thanks for all the advice everyone. went with a spec stage 1 from lmperformance. should be arriving tomorrow and hopefully will be putting it along with new slave and master over the weekend or early next week.
