Clutch diagnosement
Old 03-31-2012, 07:29 PM
Sladester2's Avatar
Default Clutch diagnosement
Well... Clutch sticks under high RPM's. Sometimes gets impossible to shift when I really get on it also. Also sometimes when I first start the car it is hard to shift into reverse. Anyone know what is wrong? And where could I take my car to to get my clutch and everything checked out? I would rather have somewhere good than just a local mechanic.
Old 04-01-2012, 01:40 PM
Sladester2's Avatar
Does it sound like the Master cylinder to anyone?
Old 04-03-2012, 08:48 AM
Sladester2's Avatar
Dang I usually at least get a shot in the dark answer.
Old 04-03-2012, 11:27 PM
Fry_'s Avatar
You need to bleed you clutch, and either your master or slave cylinder are probably on there way out. If you don't have a speed bleeder this will save you from having to cut a hole in your cars transmission tunnel.
Old 04-03-2012, 11:38 PM
Sladester2's Avatar
Thanks alot
