clutch problem?
Old 04-29-2012, 06:19 PM
hodge9386's Avatar
Default clutch problem?
yesterday i changed the trans fluid ( syncromesh works great btw) and flushed the master. i gravity blead it seemed to work fine when i test drove it but i come back to the house and when i left again it felt weird so i started playing around a lil and noticed when im in a gear and i floor it the clutch slips and then catches. iv reblead the clutch many times the normal way and it still does it. so do i just have a bunch of air in the lines or is my clutch going bad, or something else wrong? also when im bangin gears it grabs just fine, i will break the tires loose going into second and chirp third like normal.
here is a vid i took, im in 5th and give it about 3/4 throttle, you can see the rpms go up when it slips then they come back down when it grabs.
http://www.youtube.com/watch?v=ql7ss8IOoZ0
Old 04-30-2012, 04:37 PM
hodge9386's Avatar
anybody?
