What's This Noise? (video) - LS1TECH
Thread Tools Search this Thread
Old 04-05-2012, 01:22 PM   #1
Default What's This Noise? (video)
I just finished replacing my clutch and it feels like it drives great so far. The only thing is that sometimes when shifting into a new gear (most often on the 1-2 shift but sometimes on others), it makes a deep humming/vibrating sound and I can feel it in the shifter slightly. It only lasts for a second. It seems like it goes away as soon I release the clutch pedal. If I keep the pedal down it seems like it last just a fraction of a second longer than it otherwise would. Again, it doesn't do it all the time, maybe 30-40% of the time on the 1-2 shift and less with the other gears. Any ideas?
Here are the videos I just took. You can hear it right away on the 1-2 shift but you'll probably have to watch a few times as it is not very loud.
First video: http://s242.photobucket.com/albums/f...ns_Noise_3.mp4
Second video: http://s242.photobucket.com/albums/f...ns_Noise_2.mp4
1quickTransAm is offline   Reply With Quote
Old 04-07-2012, 11:45 AM   #2
anybody have ANY ideas???
Old 04-08-2012, 09:34 PM   #3
Second gear syncronizer.
Black96z28 is offline   Reply With Quote
Old 04-09-2012, 08:13 AM   #4
Thanks for the thought. The trans was rebuilt 6,000 miles ago by a company that specializes in T56s so that would be a surprise!
I been observing it more and here are some additional things I've noticed that make me think not a syncro...
It will "hum" even after it is in the new gear until I re-engage the clutch. It made the humming noise again last night and I just kept the clutch pedal down to see what happened and it continued for about 4 seconds until I let the peddle up.
By the way, your car looks GREAT Black96z28!
Old 04-11-2012, 10:21 AM   #5
This sounds EXACTLY like what I've got going on:
Buzzing noise when shifting & shift rattle - ls1 T56
I didn't replace my pilot bearing (bushing actually) when I did my clutch swap because the old one only had 6,000 miles on it. Do you really think this could be the issue?
Old 04-12-2012, 03:26 AM   #6
bongva's Avatar
Yours sounds more like a thump than a buzzing noise...
bongva is offline   Reply With Quote
Old 04-12-2012, 08:18 AM   #7
Yeah, in the video it did because it was really short. When it happens, I noticed that it pretty much stays making the noise/humming/slight vibration until the clutch is re-engaged.
Old 05-06-2012, 12:57 PM   #8
Pulled the trans this weekend and found the culprit - a slightly bent flange on the throwout bearing. I replaced the pilot bushing while I was in there too so it could have been a contributor, but since the throwout bearing flange was visibly bent I'm pretty sure that was it.
Old 05-06-2012, 03:18 PM   #9
I doubt the throwout bearing or pilot bearing is going to make the difference your looking for. I personally don't think theres a problem at all. The noise you're probably hearing is the disc rattling on the input shaft as you change gear. Every time an upshift is made, the disc has to be drasticly slowed down to match the next gear and sometime it will make noise. If it makes you feel better, my car has always made the noise your hearing.
BarneyMobile is offline   Reply With Quote
Old 05-08-2012, 12:24 PM   #10
The new throwout bearing and pilot bearing DID solve the issue - that's what I was trying to say. I've driven for a few days and its been perfect the whole time.
Related Topics
Thread Thread Starter Forum Replies Last Post
Fixed My T-Top Leak! (write-up inside) 1quickTransAm General Maintenance & Repairs 24 06-06-2015 11:30 PM
DIY Remote Bottle Opener - Pics & Videos! 1quickTransAm Nitrous Oxide 17 06-04-2012 03:23 PM
Interior Carbon Fiber Project - FINALLY DONE!!! 1quickTransAm Appearance & Detailing 175 11-15-2011 08:05 AM
I need your help guys...Engine Noise. Sounds Bad.... hazards280 LS4 Performance 33 12-28-2010 09:46 AM
Real Street Finals vid. zssman Chevrolet Performance LSX Challenge Series & Shootout 2 10-11-2010 10:42 PM
Tags
bearing, brake, break, buzzing, catback, change, click, clutch, ls1, noise, pilot, replace, sound, swap, t56
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
