T56 downshift problem. PLEASE HELP - LS1TECH
Thread Tools Search this Thread
Old 04-10-2012, 12:26 AM   #1
Default T56 downshift problem. PLEASE HELP
Recently purchased a t56 with 11,000 miles. Everything works perfect accept when I downshift from 3rd to 2nd it wont go into gear ad you slam it. Going 1st to 2nd it works perfect. Does anyone have any idea?
98camaro5 is offline   Reply With Quote
Old 04-11-2012, 09:05 PM   #2
Technical Facepalm
crainholio's Avatar
Mine had the same problem, downshifting into 2nd just wouldn't work. On teardown we found the blocker assembly was shot.
crainholio is offline   Reply With Quote
Old 04-19-2012, 05:05 PM   #3
yeah i had the same issue. then i replaced the blockers and the synchros. it did fix the "hard to downshift". might be some thing to do with the master cylinder if your down shifting and trying to get the RPMs way up tho. i had orginally replaced my master and slave thinking it was a pressure problem, but it did not fix "the hard to get into gear". replacing the synchros and blocker rings was fairly cheap and did fix my trans problem.
Todd Neyman is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
T56 Re-build 3-2 downshift lock out mintws6 Manual Transmission 1 05-31-2016 09:45 PM
T56 downshift problem. PLEASE READ 98camaro5 Manual Transmission 1 04-13-2012 11:30 AM
T56 downshift problem 98camaro5 Manual Transmission 0 04-09-2012 10:10 AM
T56 Doesnt like 2nd gear GreenBlood55 LT1-LT4 Modifications 19 01-10-2012 10:28 PM
T56 acting up stupercharged Manual Transmission 1 07-04-2010 11:45 AM
Tags
56, downshift, downshifting, engine, hard, ls1tech, manual, problem, problems, shift, stall, stiff, t56, transmission, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
