Did Drill mod and it's worse!!!! help
So I did a set a motive 3.90 gears and drill mod over the weekend. Gears came out perfect no whine what so ever. The drill mod on the other hand made my clutch issues worse. The pedal always cought low which it still does, and i had the sticking pedal after spirted driving. But now if a rev the car more than 4500 rpm the pedal just goes limp and falls to the floor. After about a min if i pump it it will slowly go back up.
It's like flipping a switch, driving normal around town it's fine but once i go full throttle it just falls to the floor. I bled the system about 6-7 times, it was bad before but not like this .
Anyone else have this issue, this sucks i just wanna drive again.
Update, ended up reading a lil more and decided to try and pull the clutch pedal spring and so far it is working. It also took out any play in the pedal and really tightend it up. I really haven't had a chance to really get on it cause I'm breaking in the gears but so far so good
