Tick remote bleeder question... - LS1TECH
Thread Tools Search this Thread
Old 04-24-2012, 12:55 AM   #1
jt76's Avatar
Default Tick remote bleeder question...
This may be a dumb question but how does one close the bleeder? I have it screwed all the way in but the fluid keeps coming out...
jt76 is offline   Reply With Quote
Old 04-24-2012, 01:04 AM   #2
Are you using an 11 and 14 wrench combo to close it? I just installed one over the weekend when me and a buddy put in my LS7 Clutch. Make sure you hold one end with a wrench and tighten the other end with the other wrench. It shouldn't have fluid coming out.
This remote bleeder should be mandatory for all when doing a clutch.
jthunderz28 is offline   Reply With Quote
Old 04-24-2012, 02:40 AM   #3
Fry_'s Avatar
^^ +1 no problems with mine. I had to crank it kind of tight the first time because of the thread sealer they put on it.
Fry_ is offline   Reply With Quote
Old 05-03-2012, 10:36 PM   #4
Uneverknow's Avatar
my remote bleeder works great. only thing i'm thinking of doing is finding the correct size speed bleeder so i only have to pump till the airs all out the line. anyways you probably just need to crank it down tighter. good luck.
Uneverknow is offline   Reply With Quote
Old 05-03-2012, 11:01 PM   #5
Fry_'s Avatar
Tick Performance's bleeder already has a speed bleeder.
Tags
bleeder, install, installation, installing, instructions, ls1, ls1tech, performance, remote, speed, summit, t56, tick, trans, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
