Tranny rebuild - LS1TECH
Tranny rebuild
Thread Tools Search this Thread
Old 04-25-2012, 11:56 PM   #1
Banned Scammer
Default Tranny rebuild
welp 3rd is starting to pop and grind.
thinkin about sending it to tick for a rebuild and order a MC while im there.
what options should i get?
BashamWS6 is offline   Reply With Quote
Old 04-26-2012, 01:04 PM   #2
LS1Tech Sponsor
Matt@Tick's Avatar
Depends on what kind of power levels you are/will make? Our most popular build is a Level 2 which supports up to 600rwtq. What are your plans for the car, Strip, Road Racing, Street??
Matt@Tick is offline   Reply With Quote
Old 04-26-2012, 01:28 PM   #3
Banned Scammer
Its a DD now. It will be seeing strip this summer. I wan to get a d1sc either this summer or next as well. So id be making about 500 but my ultimate goal is about 700.
Old 04-26-2012, 02:01 PM   #4
LS1Tech Sponsor
Matt@Tick's Avatar
I would suggest doing a level 2 or Level 3 (if you want to plan for the 700hp later). As far as options, we suggest doing a new bearing kit at least, that way all is fresh with all new bearings inside the trans. The other options are up to you. If you have a 2000+ model fbody you already have a viper second gear.
Keep in mind that once we get your trans here and taken apart, if anything is broken or bent that is normally reused, that would be additional expense. If you are popping out of gear is could be something as simple as shift forks missing, OR maybe a bent shift fork. Either way we always call once the trans is apart to give you an update.
Let me know if you have anymore questions. Here is the links to our rebuilds:
http://www.tickperformance.com/1993-...camaro-trans-am/
Old 04-26-2012, 03:28 PM   #5
Banned Scammer
What are the bungs and sprayers? Option? And as for the faceplating, i dont believe i will need that?
Old 04-26-2012, 03:43 PM   #6
LS1Tech Sponsor
Matt@Tick's Avatar
Faceplating is strongly recommended for RACE CARS only. Its not a street friendly setup.
Bungs and Sprayers are up to the purchaser, it simply sprays tranny fluid on the input to keep it from starving from fluid and burning up. Again if you arent planning to make it an all out drag car and its going to be mostly street, it would really benefit you. The idea is to keep fluid on the input shaft when a car is "lifting the front" and the fluid in the trans travels to the back starving the input.
Old 08-01-2012, 02:52 AM   #7
Papa Wells's Avatar
it would benefit or wouldn't? would you recommend bungs and sprayers on a level 2 t56 rebuild for a 500whp street daily driver car? just curious, should be looking into a rebuild soon.
Papa Wells is online now   Reply With Quote
Old 08-06-2012, 02:04 PM   #8
Turnin20s's Avatar
^^^I'm also interested in that. I thought it was only for race cars, but my car sees a lot of hard pulls and I'm curious if I would benefit from the sprayers. Does the option come with a pump or would the customer have to add that? If I would have to add the pump which one do you recommend?
Turnin20s is offline   Reply With Quote
Old 08-07-2012, 04:45 AM   #9
00'BlackZ28's Avatar
Ever heard of this
http://rktperformance.com/customer-gallery/rick-kim/
he did mine. Still feels like new.
00'BlackZ28 is offline   Reply With Quote
Old 08-11-2012, 08:01 PM   #10
LS1Tech Sponsor
Matt@Tick's Avatar
The customer would supply the pump set-up after we weld the bungs and sprayers into the case of the trans.
Related Topics
Thread Thread Starter Forum Replies Last Post
Wtb t56 rebuild kit leonrvn Parts Wanted 0 08-14-2016 10:55 PM
ls2 rebuild showdog75 Generation IV Internal Engine 0 12-11-2014 07:23 PM
ls1 rebuild kit superman2002 Generation III Internal Engine 8 03-27-2013 07:54 AM
Vortech v9 Gtrim rebuild mmorellicamaross Forced Induction 6 07-09-2012 07:22 PM
Fbody caliper rebuild kit? FOSTER21 Suspension & Brakes 2 09-20-2011 04:53 PM
Tags
99, bungs, forks, kim, ls1tech, padded, papawells, rebuild, rick, shift, sprayers, t56, tranny, trans, transmission, transnission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
