99 ws6 5.7 a4 to 01 firewawk 5.7 m6 need some help
Old 06-26-2012, 10:41 AM
firehawk68mcleod's Avatar
Default 99 ws6 5.7 a4 to 01 firewawk 5.7 m6 need some help
Ok here's the run down, I have a 99 ws6 a4 trans am i blew up a while back. Well, i came across this 2001 firehawk engine and t56, and i thought i might as well swap it to a m6 while i was in there. Here's what i got with the engine and trans: m6 pedals and sensors, crossmember, m6 wiring harness and computer.
I need help with two things:
First, where to cut the hole in the floor pan for the t56 shifter. Pics if possible.
Second, how do i hook up the neutral safety switch on the a4 shifter and the clutch pedal sensor. Also i noticed stick cars have a manual flip switch to allow you to turn the key where autos dont.
Thanks for any help.
Old 06-26-2012, 12:22 PM
I really need some electrical info on the a4 to m6 interior side of the car
Old 06-26-2012, 01:05 PM
the_merv's Avatar
https://ls1tech.com/forums/lt1-lt4-m...ml#post9915099
