After LS rebuild, T56 wont go into gear
I just rebuilt my motor. It is completly stock and i mainly focussed on the bottom end. However, before the rebuild, my T56 was working fine. After, my T56 dosnt want to go into gear. When I am driving normally, it goes in without any issues but when I am hard on it, it will refuse to go into almost all the gears. Even reverse. Now I know a little about syncros but could it possably be my clutch going out? I have blead my clutch several times thinking there was still air in the system. There might still be but after all the bleeding, it pretty much stayed the same. So my options that I know of are: re-bleed it, buy a new clutch, or rebuild my trans. I do want to state again that it worked perfect before my rebuild. Hope fully some one knows or can guide me to an answer. It's a 2000 all black Firehawk by the way.
