Re-using a clutch?
Re-using a clutch?
I have a clutch that I want to put on a different engine. It only has 500-750 miles on it. Do I need to use it with the same flywheel, or can I use it with one with a fresh surface? I would like to keep the flywheel with the engine it came off of for balancing purposes.
Agreed: Shouldn't be an issue with the mileage. I once had a 2000 mile pressure plate resurfaced, with a resurfaced used flywheel and a new clutch disc. That was a smooth *** clutch.
